k20a3 with prc K-Pro ecu
burtcrx
Post by burtcrx »
Hi, I would like to know if I can run properly a k20a3 head with a PRC Kpro ecu...?
And at the time did anybody heard about making working cams k20a2 into k20a3 head...I tried I put in rocker shafts, arm pins of an A2 in the A3 head...but the cams locked...seems like the rocker shaft does not bring oil pressure... I'd like to know that too thanks!
www.inlinepro.com
With regards to the ECU and wiring the K20A2 and K20A3 heads function in the same way. Mechanically they are quite different, including the rocker shafts as you have found. The part that is difficult to get around is the lack of lost motion seats in the K20A3 head.
burtcrx
Post by burtcrx »
So, With hondata, my prc ecu can run the k20A3?
Garrett_si
Post by Garrett_si »
burtcrx wrote:So, With hondata, my prc ecu can run the k20A3?
yes
