BlueprintRacing Stg 2 calibration
Hello, does anyone has a base calibration for a JDM K20A with Blueprint Stage 2 cams, or which calibration should I use? thanks
Garrett_si
Have tried with the ITR base map but it was worse than with the OE cams, tuning it only pulls 190whp, and with the OE cams did 208whp. After a few hours changing the cam angles (lower) it did pull like with OE cams all the way to 8000rpm and pull 214whp only at 8100-8500rpm !! This is not what I expected from a stage 2 cam... Can anyone please check my calibrations please, or there's a specific cam angle for these cams... :?
Here is the dyno chart, blue with OE cams and red with Blueprint 2 cams. (there is no difference at all...)
Garrett_si
this might be help http://hondata.net/forum/posting.php?mo ... ed7999905a
i had the same problem , i ran a set of brian crower stage 2 cams for about 2k miles. car had less power with them than with stock type s cams , seemed no matter what i did , was no gains. so i finally decided to take them out and put stock ones back in. im so glad i did , cause one of the lobes on the intake cam was wore rght down , badly. and one of my rocker arms , one mind you , was tapping on the top of the retainer slowly chewing it away , taking nibbles. it seems to me , FOR THE MOST PART MOND YOU , all aftermarket companys want is your money. the quality of parts they sell you , pales in comparison to OEM stuff. thought id share. nothing like wasting 1000 dollars on cams and valvetrain.
