unplugging hondata question
EG-nath
Post by EG-nath »
hi there
i have a hondata s200 unit connected to a chipped p28 ecu
my question is can i unplug the s200 unit from the ecu and then use the ecu as normal with a new chip installed?
no one can hear you scream at 9000rpm!! www.nath106.co.uk
You may hav eto replace J12 and it all depends on the chip you use.
EG-nath
Post by EG-nath »
well the reason i asked is because every chip i use (i have like 4 or 5 now) i get this problem
http://hondata.net/forum/viewtopic.php?t=7998
so i was thinking id try it with the s200 unit disconnected and see what happens
do i have to use a chip that has been tuned with hondata for the above not to happen? or can i use a base map with no problems? if that makes sense??
The interface box will only work with a Hondata ROM.
