CAM Command always at 0
magnEsium
Post by magnEsium »
A friend just bought K-Pro, I gave him a kal for his vehicle and his cam command is always at 0, it does not change ever even though the tables say otherwise
No CEL's thrown, VTC is enabled, just simple bolt ons, 2005 rsx-s
Car is warmed up, all engine sensors were checked and rechecked
Any ideas?
magnEsium Tuning
http://www.magtuning.com
rdiablos330
Post by rdiablos330 »
how do i find the serial number? i cant find the paper..
06 rsx type s
kpro
injen cai, rbc manifold, sturp rh, tanabe catback
the problem i have is what magnesium said
open the lid and look at the K-Pro board.
rdiablos330
4087 is my serial number
rdiablos330
so any comments on what could be wrong with the car??
You have an error code - P0112 "IAT Sensor Low Voltage"
magnEsium
Post by magnEsium »
Hondata wrote:You have an error code - P0112 "IAT Sensor Low Voltage"
That wouldn't cause the angles to lock at 0, would it?
magnEsium Tuning
Yes it will.
rdiablos330
ya thats the code.. so just get a new iat and im good?
If there are an error codes always track down and fix them before doing anything else.
Follow the Helms manual troubleshooting for the IAT error code.
rdiablos330
i put in the new sensor and the code is still there. once i clear it it comes back on. when i clear it n dont let it idle on its own, by revving the car it stays off. but it works the whole time as long as i keep the rev high.. once i let it idle alone the engine light comes right back on and the kpro craps out.. what should i do? and i dont have the helms manual where can i get one?
