I am sure this topic has been beaten to death, but still i am not satisfied with the answers i have found.
I need to pass emmisions on 2002 si with a jdm k20a swap, full race header and kpro tuned prd ecu.
My question is would i be able to pass using my PNF or stock 2002 si ecu and an o2 simulator like omni powers or somethign similar?
My thought is that if i drive the car to the shop, switch ecu's in the bay (yes i happen to know these guys) take out my wideband and throw in a normal o2 sensor with a o2 simulator to make the os sensor believe it's reading catalized gases, will this work.
If not any suggestions are welcome.
much appreciated
Emmisions testing with a PRD ecu
Garrett_si
checked code
I checked all my rediness codes and they all come up as Not Supported. In another posting you said this was OK. That means i should be able to pass emissions? Keep in mind, i do not go on a dyno or use the sniffer for my emissions in ny state.
