I'm wondering if I can make this combination work in a kit car, NOT a Honda Body.
A Civic SI Manual transmission with LSD, 06 TSX Engine, and 06 Wiring Harnesses with the Kpro.
Can any experts offer an definite answer?
It was initially suggested to me to use an RSX S transmission with this combo, but it lacks the LSD.
Kpro with 06 RSX wiring Harness, 06 CivicSI tranny,06 K24A2?
Garrett_si
You should not use the 05-06 KPro with an engine swap unless the engine swap wiring uses the correct 05-06 E connector wiring. To the best of our knowledge no engine swap wiring kits that you can buy do this, so most people just plug the E connector into the 02-04 ECU, which is something we specifically prohibit.
