PLEASE READ!! HONDATA S300 ISSUES!!!
tvctorj
Post by tvctorj »
I'm new to this so please bear with me..
I purchased the S300 + P28 ECU bundle.
This is going into a Civic SI 2000 (B16A2). Since this ECU was esentially "plug and play" I plugged it in, put the S300 in it. Once I did that the ECU would not turn ON meaning that on the S300 there are little LED's that light up, they don't light up!!
Does this mean that the ECU is not getting any power?? The S300 came with some extra items, a capacitor, some resisters, and some pins.. Do I need to use these?
I tried to interface with the S300 with the updated software becuase I thought that maybe it needed to be activated or something.... NOTHING HAPPENED!!!
I could not link up, the computer couldn't find the S300!!
Please help me!! I have a tuning session coming up and I need this fixed ASAP!!
The first thing to check is that you have the right ECU for you vehicle - OBDIIA or OBDIIB. Your car should be OBDIIB. Note that you can successfully plug the connectors into an OBDIIA adapted ECU, so you need to check that the ECU says OBDIIA.
tvctorj
Post by tvctorj »
Hondata wrote:The first thing to check is that you have the right ECU for you vehicle - OBDIIA or OBDIIB. Your car should be OBDIIB. Note that you can successfully plug the connectors into an OBDIIA adapted ECU, so you need to check that the ECU says OBDIIA.
It does say OBD II A (The P28ECU)!!! Does that mean I have the wrong one??? If I do, there are adapter harnesses right that convert OBD2A to OBD2B???
**GASP!!
Your car is OBD2B, you have the wrong ecu. Contact your dealer that you purchased this from.
