Honda GSR ECU help!!!
Michael1989
Post by Michael1989 »
I just recently swaped a B18c GSR into my '96 civic ex coupe and the ecu they sent with the B18 does not plug up to my wiring harness from my civic and the stock was used for now....until tropical storm fay stalled out my civic and burned up my P2P. Now i need a new ecu (OBD1 or OBD2) but if i can i want to use the gsr ecu if it is possible to get it to plug in (without changing my wire harness) i need it badly! Anyone know what i could do?
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
http://www.hondata.com/obd2promotion.html
