G-sensor and 2nd ignition trigger question.
ROM Editor 4 tuning software questions and answers.
Carchitect
Post by Carchitect »
I have the G-sensor installed in my S200. Will it still be supported in RomEditor 4? If so I may be upgradng to it or going the S300 route.
Also I plan on adding triggers on the OEM cam gears and simulate TDC and CYL position sensor inouts for the ecu and add the OBD-2 oil pump and CKF sensor for CRK trigger inputs for the OBD-1 ecu. Needless to say I want to ditch the OEM dizzy. I won't mind running waste fire but only have 1 trigger out from ecu. Can we add another trigger to the ecu?
TIA
-Joe
Experience is what you get when you don't get what you want
08 IS350 Sport Package, Levinson, Nav, Radar cruise.
94 JZA80 6speed undergoing major weight reduction AKA 911 GT2 killer.
90 DA9 B18C5 retired auto-Xer
Romeditor 4 does support the G-sensor, but I would highly recommend just upgrading to the s300. There is no way to have a second ignition output at this time.
