Closed loop and wideband.
FrodoGT
Post by FrodoGT »
So I have an AEM Wideband and I have been running the 0-5v output to d14 (o2) to tune with. However I was wondering if it was possible to use the wideband to run in closed loop? I have set it up and yet nothing happens, no short trim or long.
I attached a screen shot of my settings if it helps any.
No you cannot run in closed loop from a wideband signal. It will not work. You can only run in closed loop from a narrow band signal. The AEM can only output one signal at a time. This is why we only recommend the PLX widebands (they have both narrowband and wideband).
FrodoGT
Post by FrodoGT »
I understand the issue with the single output on the aem. I just thought that using a wideband signal could somehow be more accurate in keeping a target AFR. I guess Ill put my narrowband back in and run them both, no biggie.
laziebun
Post by laziebun »
im not really understanding this close and open loop. i tryed to read about it but still doesnt make any sence to me at all. Can someone on here put it in a ABC for me?
killer2239
Post by killer2239 »
I am setup the same way. Have the AEM in d14 and no stock o2 sensor hooked up. Will there ever be a future upgrade of s300 to allow the wideband to be used for closed loop in its place?
2004 Honda S2000
No. This is why we only recommend the PLX widebands as they have a wideband and narrowband output at the same time.
killer2239
Spunkster wrote:No. This is why we only recommend the PLX widebands as they have a wideband and narrowband output at the same time.
Thanks for the info Spunkster. Luckily my other friend will be going the plx route after learning this.
2004 Honda S2000
