controlling rad. fan by K-pro
jdmdc529
Post by jdmdc529 »
I just wanted to make sure i am correct on this diagram to have the k-pro control the fan.
Instead of the gray/white wire off of the relay going to the fan switch, do i splice that into b6 to control the fan from the k-pro? Or, do i splice the black wire out of the relay into b6 for the k pro to control the fan?
BTW: I do not have a fan switch
thanks! and anything else i should change?
You need to use a proper fan switch. The ecu control of the fan is just a backup in case of a problem with the fan switch.
jdmdc529
Post by jdmdc529 »
Spunkster wrote:You need to use a proper fan switch. The ecu control of the fan is just a backup in case of a problem with the fan switch.
Yes i understand that, but would the gry/wht wire just be tapped in the the harness for it to work?
jdmdc529
Post by jdmdc529 »
Does the b6 pin to control the fan put out a power or ground?
turbogixxer
Post by turbogixxer »
jdmdc529 wrote:Does the b6 pin to control the fan put out a power or ground?
It is a ground.
