PROBLEMS WITH CIVIC 07 SI REFLASH AFTER ALMOST A YEAR
manutex
Post by manutex »
SUDDENLY MY CAR WONT START AND I HAD MY FRIEND TO SCAN IT WITH THE OBD SCANNER AND IT SAYS P0606 ECM MALFUNCTION ANY IDEAS WHAT CUOLD IT BE?
There's no need for all caps.
You will have to get it checked out at your Honda dealer. There is nothing in the reflash that would cause this.
manutex
Post by manutex »
Would that reset my reflash and go back to factory settings and lose my $650 inversion ???
Before you worry too much about the reflash you need to determine what the actual problem is and get that taken care of.
manutex
Post by manutex »
finally whent to the dealer and they had to change the ecu for some reason the engine inmoblizer was not working ny not letting the car star. at least the warranty cover it. so i lost my reflash and my money and now i see a recall for my ecu
