PROBLEM! NEED HELP!
Birdley42008
PROBLEM! NEED HELP!
Post by Birdley42008 »
Okay when I start my car cold and let it warm up, I have a green light, then I drive normally, and when the car is warmed up I am just getting on the highway, at around 5th gear, 10+psi, going 80mph+ just for a second to merge on, not smashing it, feathering it up to speed, and then slowing down.
The problem is sometimes on the highway I get a solid , red and green light, i dont believe its an error code! The light will go back to solid green if I start to coast for about 5 seconds on the highway! And then i will never see it again!
Any Ideas, Im at school I could really use some advice!
Thanks.
Do you have on-board datalogging turned on?
Birdley42008
Hrm... should I turn that off, Its always had the on-board datalogging. Does it turn on at a certain point or something?
Is the red green light something to worry about.
97 Civic DX HB- stock D16y7/z6 IM
Master Power Turbo - T3 .42/.48
Doing the best I can with a single cam, no vtec, and 178whp.
13.470 @ 101.61mph 09'
13.343 @ 100.52mph
Tuner Toys - Quality parts that last!
http://www.tunertoys.com/?Click=44
turn off on-board datalogging. There is no reason to have it always on.
Birdley42008
will that account for the red/green light!
13.343 @ 100.52mph
