engine. ECU identification
rusco
Post by rusco »
HI-
I have a 93 DX. How do ID the engine and ECU? Can I buy/build a cable and use any readily available softwware for data logging, error codes?
Thanks,
Russ
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
rusco
Post by rusco »
Thanks for the reply/info. Can I get stock 'files' or the code that is burned to the ROM? Say, to study a stock fuel map to one that is 'tuned'?
Download and install Smanager and then go to File, NEw to see the built in basemaps.
