vtec
hyro
vtec
Post by hyro »
hi
i am having a problem with vtec entering too early. i have setup a lower boundary of 5200rpm and 80kpa pressure.
when i reach 5200rpm, whatever the pressure is, i am entering vtec tables.
hyro
Post by hyro »
sorry,
don't know the serial number of the ecu, it's a friends ecu.
here is a datalog and the kal. the kal is not finished, so, fuel maps look weird.
THis is because you are using Alpha-N. The TPS signal is being translated into a map value. If you look at the datalog even while the car is not running but on positiona and datalogging you will see this.
hyro
Post by hyro »
Spunkster wrote:THis is because you are using Alpha-N. The TPS signal is being translated into a map value. If you look at the datalog even while the car is not running but on positiona and datalogging you will see this.
yes, is using alpha-n. the car is running with itbs. but using alpha-n, ecu doesn't look for pressure to activate vtec?
Spunkster wrote:The TPS signal is being translated into a map value.
hyro
Post by hyro »
ok, but i don't understand how this affect to vtec entering at a certain rpm without looking for pressure to activate?
i am runing alpha-n on my own car and it is working ok.
rikitaun
Re: vtec
Post by rikitaun »
hyro wrote:hi
menudo tunero de palo tu y el Uri :D
hyro
Re: vtec
Post by hyro »
rikitaun wrote:
hyro wrote:hi
dile al dueño del coche que me lo trae defectuoso.
rikitaun
Re: vtec
Post by rikitaun »
hyro wrote:
rikitaun wrote:
hyro wrote:hi
jajajaja, como coño has puesto el TPS en la columna ????
no lo veo como opcion por ningun sitio...eres un puto friki
