How do i revert a hondata ECU to run as stock?
sung
Post by sung »
I purchased a ECU that was already chipped/socketed for hondata but i need to use it without the hondata settings for a little while... what do i have to do to make it run like a stock ECU?
cut jumper J1
Phat4Door
Toggle switch?
Post by Phat4Door »
So if I send my GSR ecu off to hondata and get it chipped and then get it back and put a toggle switch on j1 I can put it in my car and run it until I can get a base tune and then flip the switch back and forth between stock and the hondata? Is this correct, because if so I will send my ecu off monday.....
Phat4Door
Post by Phat4Door »
Anyone? I can't find an answer to this one anywhere hoping someone on here can help me....
Yes you can, but why?
Phat4Door
Post by Phat4Door »
Basically so when I get my ECU back from being chipped I can still run the GSR program until I have the time and money....mostly the money to pay to get it on the dyno that is 1 and a half hours away to get the base tune, once I get the base tune I don't need the switch, but basically I was wondering that so I didn't have to go out and get another GSR ecu to run my car until I got the base tune....Thanks
