Check this out
ROM Editor 4 tuning software questions and answers.
tsrperformance
Check this out
Post by tsrperformance »
Ok, so I tuned this car last week on a small turbo. Customer changed the turbo and came back for a retune. He changed the turbo and the map sensor. Put it on the dyno, get it rolling to calibrate the dyno and this happens. It only happens going into 3rd gear. Changed ECUs, changed blue boxes, changed interface cables. The only thing i can think of is that my RE4 Cable took a dump on me or my romulator took a dump.
Also, I threw a s300 in just to see and it worked perfectly. So im pretty sure it cant be a harness issue
Thanks for the help
An actual description of the problem would be really helpful
tsrperformance
as soon as i put it into 3rd gear to calibrate the dyno, the rpm, map, duty, iat, ect, etc. goes irratic and the car tries to jump off of the dyno.
Its hard to explain but in the log it shows what im trying to explain. thanks
tsrperformance
fixed. it was a faulty romulator
