MAP
babybenz
MAP
Post by babybenz »
What should MAP sensor read at idling? Mine indicates a negative value. of -10-13"/psi during cold start. Is it normal?
Regards
+65-9296-5336
All depends on your setup, but typically a heallthy engine will idle with about 20 inches of vacuum.
babybenz
Post by babybenz »
spunkster,
but mine is -13" plus. does it mean my engine is not healthy?
i only have 81.5mm wiseco pistons, toda c2 cams, stock type-r conrods, flat-bottomed valves, dual valve springs, etc in an ek9 engine.
Regards
+65-9296-5336
Have you talked to your tuner/engine builder?
