AIR CON WIRING CONNECTED TO S300
babybenz
Post by babybenz »
My mechanic told me he connected the air con wirings directly to the S300.
When i switched on the air con, air con compressor/clutch starts.
When i switched it off, air con compressor/clutch still runs. I need to switch off engine completely to turn off the air con.
I do not like this. Pls help. Which wiring should I remove/deactivate from the S300?
Regards
+65-9296-5336
Not knowing how this is wired in your car, it is nearly impossible to say what the problem is. I would highly suggest getting a Helms manual (factory service manual) for your vehicle to make sure everything is wired correctly.
