pnf ecu reflashed wit a k20a2 map
civicsibaby04
Post by civicsibaby04 »
is it possible to reflash a pnf ecu with a k20a2 map????
I think this relates to your other post. The answer is that it depends on the exect PNF ECU that is used.
We cannot reflash a PNF ecu with a PRB calibration. If you have done an engine swap then you will need to get the K-PRo.
