Having problems with logging AFRs
SovXietday
Post by SovXietday »
I have a PLX M300, 5V output is running through D10 (ELD). I had this working before on a much older version of Hondata Smanager (I want to say 1.2) with no issues.
Updated Hondata and now the ECU will no longer correctly log AFRs. I have the wideband source in the Closed loop tab (in Parameters) set to D10(ELD) but the ECU is still trying to log AFRs through O2. Any fix for this? I am running version 1.3.8.0
Thank you.
You can post your calibration & datalog, or email them to support@hondata.com ?
Have you uploaded the calibration using the new version of software?
SovXietday
Spunkster wrote:Have you uploaded the calibration using the new version of software?
That fixed the problem. I had realtime update on and made some minor adjustments, I figured the ECU would update but it never did. I had to manually upload the calibration. Thanks!
