Datalogging JDM ITR - Reading wrong speed / gear?
JayK
Post by JayK »
Hi All,
Ive a JDM ITR K20a DC5. Ive put on a PRB KPRO and uploaded a base kal with breathing mods.
Did a 3rd gear pull and it was reading gear 2 instead of 3 and the speed of 2nd gear. So readying the wrong gears rather than the speed i guess.
Any help on this?
Jay
In Parameters go to Gear Comp and make sure you select the correct gear ratios.
JayK
Post by JayK »
Just checked it and it had the following ratios in my current base map given to me.
[Gear Ratios]
; Gear ,Ratio
0=1,3.266
1=2,2.13
2=3,1.517
3=4,1.147
4=5,0.921
5=6,0.738
6=7,4.764
I then updated it with what was in the KPRO Gear Comp section to JDM Integra R and its this. But still showing the wrong gears.
[Gear Ratios]
; Gear ,Ratio
0=1,3.266
1=2,2.13
2=3,1.517
3=4,1.212
4=5,0.972
5=6,0.78
6=7,4.764
Also got P0134 Air Fuel Ratio Sensor Not Active now :(
Any ideas?
Have you uploaded the calibration with the changes?
JayK
Post by JayK »
Hi
Yes i did but remained the same. I asked on the UK ITR owners site and seems a common issue as our cars are imported from Japan, and changed to MPH, and a speed convertor is put in so something to do with that.
Jay
Is the speed as read by KManager correct? (the units need to be correct too - if the speed in mph is correct but the units a kph, then you have a problem).
JayK
Post by JayK »
Its reads in MPH as it should. However its reading the wrong gears, when im 3rd its reading 2nd hence the speed is obviously going to read wrong.
cranny
Post by cranny »
it shouldnt no , cause there is no gear sensor. it calculates what gear your in using speed/revs/the gear ratio you have. or i assume anyways.
dcloo
Post by dcloo »
sorry to hijack but just wan to share
previous i don't have any speed sensor and just put provide constant speed
after some time i put back the speed sensor the motor get miss firing on 2nd and 3rd gear only in certain rpm its was gone after the engine exceed 3.5k rpm and its only happen in 1,2,3rd gear 4th gear above will fine
here some of my datalog file any 1 here can help me out?
cranny
Post by cranny »
your car needs tuning dude. post up your calibration. runs pig rich fom what i see.
dcloo
Post by dcloo »
cranny wrote:your car needs tuning dude. post up your calibration. runs pig rich fom what i see.
ok its just happen on 1st 2-3 sec on the datalog you could saw the ignition turn to -5 degree and the engine was miss fire there
when i unplug the speed sensor and provide constant speed in kpro every things will fine A/F will going back to 12.8-13.3 its only happen VSS was running/attach
VT-Doo
Post by VT-Doo »
Rather than start a new thread...I have the same/similar problem.
I have a 2001 JDM Integra Type R DC5 with a K20a.
In Japan the speedo reads KPH. When imported to the UK the speedo was converted to MPH.
When I'm traveling at 70MPH KManager reads 43MPH.
I am aware 43MPH = 70KPH
Have I simpley missed a setting within the sofware?
Cheers,
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
VT-Doo
Post by VT-Doo »
I can't test this just now but am I right in saying that in Sensor Setup the VSS should be set to KPH?
But I am wanting to display MPH in the graph and display? :?
Ian
eg6-b18c6
Post by eg6-b18c6 »
i would check how the speedo converter is wired and modify the wiring so that kpro is seeing an 'unmodified' signal. if you cant see how to do that then just remove it and have your speedo in km until you figure it out.
if you have figured it out, let us know :D
