Can't download SManager!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dang
Post by dang »
Is it just me or are all the links broken atm? I'm trying to download the latest verions of SManager and KManager with no luck.
Any help appreciated.
PH_B16-VTi
Post by PH_B16-VTi »
http://hondata.com/updates/index.php?ap ... n=download
Check again...
I'm getting:
Warning: gethostbyaddr() [function.gethostbyaddr]: Address is not a valid IPv4 or IPv6 address in /home1/hondatac/public_html/updates/index.php on line 94
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 227
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 228
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 229
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 230
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 231
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 232
Warning: Cannot modify header information - headers already sent by (output started at /home1/hondatac/public_html/updates/index.php:94) in /home1/hondatac/public_html/updates/index.php on line 233
And then the binary...
/ph
Kraiye
Post by Kraiye »
same here
at first i though it was just an incompatibility with firefox but downloads aren't working with IE either.
same errors then binary jargon.
It is working fine here. It is more than likely a problem with your ISP caching an older version of the website.
PH_B16-VTi
Nope... If you run:
You'll get:
That's a PHP Function call error, which is making the rest fail.
If this error is suppressed the header warnings will go away.
I can see the Binary file also, so the cache is right.
[quote]
MZPÿÿ¸@º´ Í!¸LÍ!
Something to do with the headers your ISP is sending. Should be fixed now.
Do not link to http://hondata.com/updates/index.php The correct place for downloads is http://www.hondata.com/downloads.html
Kraiye
Post by Kraiye »
working fine now
thanks Hondata :)
