getting VSS error code!
laziebun
Post by laziebun »
Im getting a VSS error code. The code doesnt pop up right away but, it pops up while im driving and come in within 5 mins. But the speedo still works fine. It also act weird while im driving, it give a lilttle studder and and when i give it just a tad bit more gas it GOES. This is all happening while the VSS error code it on. what can it be?
laziebun
Post by laziebun »
clibration attach
datalog attach
honda civic 1999 gsr swap
P28 ecu
Boosted
and this problem ust started...also around 3000-4000 it stutters
and its not showing my AF like it did before i reformated my computer
[/b]
The problem is your wideband input settings in the closed loop tab. You have all the same lambda/air fuel values.
You have a problem with your VSS signal and it is triggered when you decelerate between 4000-3000 RPM.
laziebun
Post by laziebun »
well there are two rows and three columns
voltage 0.00 5.00 5.00
air fuel 7.35 22.39 22.39
How should i do it
lc1 call for 0v = 7.35 and 5v = 22.39
Ignore what i said about your closed loop tab, I opened your calibration with a beta version of software that had showed the wrong information. The problem is your ELD input has 4.98V at all times.
laziebun
Post by laziebun »
im using d10 so what should the ELD be reading?
The voltage from the wideband output of the PLX
laziebun
Post by laziebun »
well i found out why my wideband reaing was off just incase someone else is having the same issue..
i went to SENSOR click on AF and change the settings.
