Boost control circuitry for P72-0 / S300J ?
OTT
Post by OTT »
Hi, as above.... is Boost control circuitry available for P72-0 JDM ecus with S300J ?
..otherwise is there any of the ECUs with knock-sensor support that will work with the Boost control?
Cheers
Only US ecus can be used with boost control. You can use a US P72, P30 or P61.
OTT
Post by OTT »
so the uk P30 WONT have circuitry?
how do I check?
thanks
Only rectangular cased ecu's can be used for boost control. If it is a square case ecu it cannot be used.
OTT
Post by OTT »
So if get a rectangular cased ecu with knock-board like ukdm or usdm then will it work with boost control? cheers
If you add the correct componenets then yes.
OTT
Post by OTT »
cheers
