Nitrous wiring problem
mron0903
Post by mron0903 »
Ok i finally got around to wiring my nitrous to my S300 and so far it hasn't worked. This is how i wired it up....
and this is from hondata's web site, and from this I see that 85 and 86 are switched from how i wired mine... Would this be the problem? Or should it still work?
You must wire it exactly as we have shown in the diagram. If you change it, it will not work.
mron0903
Post by mron0903 »
on hondata's diagram it says 12v switched, what does that mean? Do i splice those two wires together and put to a 12v source?
There is switched 12v power in the fuse box. Using a multimeter you can find the spot that only gets 12v when you turn the key to the on position.
mron0903
Post by mron0903 »
ok cool, I got it to work finally! Just one quick question, does it matter if you invert the output (A20) cause i tried both ways and the solenoid still click on either way.
