WOT column reading at 0% TPS??
dbkserieseg
Post by dbkserieseg »
hey i seem to have a huge problem. i finished my friends k-swap and used my ecu to start it up... using your k24-650cc race cal and switching the injector size to 550 and also making minor adjustments to fit and rsx cal. i started it up and got seriously rough idling.. it shut off then started and the same thing... checked my laptop and noticed no codes.. but the car stayed over in the wot columns and my tps was closed. what could it be.. i thought i was the map sensor but swapped one from my car and nothing changed at all... the motor is freshly built also. any thoughts hondata or spunkster??? i didnt datalog but let me know if you need to see one.
K20EG6 -DBKswaps!!!
cranny
Post by cranny »
what map sensor do you have selected in parameters?
