Limited Edition S300 R136 & R138
OTT
Post by OTT »
To accurately feed the 0-5v wideband signal into D10...
can you definitively tell me if I need to cut R138 & R138?
jordancivic
Post by jordancivic »
R136 and R138 yes, i had this issue a while ago and Hondata confirmed this.
If you are having a problem then try cutting them.
SPOOLIN
Post by SPOOLIN »
what kind of problem is a problem? Symptoms to determine if there is a problem would be nice.
www.MSSRACING.com
9.29 | 6.20 | 167
If the datalogged voltage does not match the voltage on the pin (using a multimeter), then remove the resistors.
Jaker
Post by Jaker »
Is it safe to say that if the resistors are there that they should be removed? Are there any repercussions to removing them for no reason?
