Radiator Fan Control
dpetro1
Post by dpetro1 »
trying to troubleshoot my rad fan control. i am running 1.3.8 and using AUX1 to control the rad fan.
so i click "generic output" then...
-input tab "always on"
-output tab a12 FANC
-parameters
RPM 0-10000
Load -3 - 20psi
Min MPH - 0
Min throttle - 0
Min air temp - 1
ECT 185 - 260
problem is the fan just comes on as soon as i turn the key to "on". i want it to come on at 185 as listed in parameters.
i wired my relay fo the fan and assume its correct since the fan works, it just doesnt follow my ECT instructions. Do i have something wrong in smanager?
Can you post the calibration? You'll want to set the minimum load to something much less than -3 psi.
dpetro1
Post by dpetro1 »
doh!!! when i converted psi to hg i was using mmHG not inHG so i thought -3psi had me covered. ill try something like -20psi (-40''hg) and see if that cures it. ill report back on saturday when i get back to the car.
EDIT: hmm actually im not sure that would explain my problem. maybe if the fan wasnt coming on at all. since the min load wasnt met.
i am using a SPST relay. should i be using a SPDT instead?
dpetro1
Post by dpetro1 »
calibration uploaded
1. On the input uncheck 'Invert Input'. An arming input that is always on then inverted is never on. Uncheck the other 'Disable' boxes too.
2. On conditions set minimum rpm to 100, and minimum engine load to -14 psi.
dpetro1
Post by dpetro1 »
Hondata wrote:1. On the input uncheck 'Invert Input'. An arming input that is always on then inverted is never on. Uncheck the other 'Disable' boxes too.
no dice. the fan will only come on when i check "invert output" and the key is at "on" position. any other suggestions?
'Invert input' or 'invert output'?
dpetro1
Post by dpetro1 »
Output. regardless of what i change in the input tab or conditions tab the fan comes on when i check "invert output" and turns off when its unchecked
tiamat6x3
nitrous / aux control
Post by tiamat6x3 »
Has anyone figured this one out? I have this same exact problem. I have tried the parameters stated above by hondata site admin but it will not turn the fans on. I know the computer has the capability to control the fan because if I check the "invert output" button it will turn the fans on but they will just always be on no matter what.
I have this same problem with nitrous control. I cannot get it to function based on parameters. Only on or off with the invert output button.
I have a p72 ecu (I think, 94 integr GSR)
Any help would be greatly appreciated.
You cannot have an engine speed of 0, it must be something above 0
tiamat6x3
Post by tiamat6x3 »
slick, that did the trick thanks.
Will it ever change it to be able to have the engine speed to 0? its useful to be able to test these things w/ out the engine running.
dpetro1
Post by dpetro1 »
LOL i thought this thread died. i should have checked back sooner. i just figured this out on my own today and was coming back to post my findings.
spunkster hwere were you a few weeks ago? :D
