injector deceleration shutoff
JPsi02
Post by JPsi02 »
Is there any way i am able to keep the injectors on during Deceleration? I dont see any option and i dont think just changing the values in the first colum matters sense it shuts them off anyway. I know theres the point where under decel you get close to idle speed (rpm) and it will turn them back on. Maybe a way to be able to raise that point so they dont shut off? Thanks in advance
The injectors are shut off from both MAP and TPS, so it would be difficult to keep the injectors on during overrun. Be aware that keeping the injectors on washes the oil from the bores with fuel, and the ring seal goes away fairly quickly.
