PLX M-Series wideband oxygen sensor OR?
gatesmith
Post by gatesmith »
Is the PLX M-Series wideband oxygen sensor the only one I can use to run a wideband with my S300 ECU for tuning?
I don't really need the gauge at all. I just want the wideband for tuning.
Something simpler? A module or something?
Thanks.
Russ
dpetro1
Post by dpetro1 »
you can use the new sm-afr module. it is a wideband module w/senor (no display unit) then just datalog through smanager
twinkam
Post by twinkam »
Would there be a difference in AFR in the S300 than the PLX SM-AFR. I thought you needed the gauge to set the difference.
Also do you have to calibrate the sensor in Smanager for the s300. If so how do I do that?
It is best to have a display so you can always see the readings, and it makes setting the offset much easier. You can use a multimeter to help you find the offset, but it will be much more tedious since you will have to convert the voltage to a AF reading in your head to get it right.
