Error Code 16
turboh22a
Error Code 16
Post by turboh22a »
Car starts just fine but runs rough at idle. removed all spark plugs cylinder one through has carbon on top of the piston and cylinder 4 is completely clean, looks like new. after car is started i remove plug wires from one through 3 and there is a change than on #4 no change. i changed plug wires with # 3 to see if it moves cylinders and nothing. Anyone got any ideas...this is the only problem keeping me from the dyno to tune..need help..thanks
im running a h22a, je 9.1 pistons 780 precision injectors stock head anyothe questions please let me know
Do a leak down and compression test. Also check for fuel and spark on each cylinder.
turboh22a
Post by turboh22a »
compression test on all four cylinders shows 150 across all 4 cylinders. any ideas now...need help thanks
albastiki
Post by albastiki »
change your spark plugs
albastiki
The most important test is a leak down test.
turboh22a
Post by turboh22a »
i reinstalled my 450 injectors still have a mis on cylinder 4. i did a leak down and every cylinder is 1%..everything looks good its making no sence. i installed new plugs and still misses. i also tryed new wires same thing. Any other ideas.
Try a different distributor.
turboh22a
Post by turboh22a »
what about the chances of the injector resistor box failing? have you seen that happen before?
