Lambda conversion tables question
Jaker
Post by Jaker »
If you change the settings in this table to run a WB O2, how do you get back to the stock voltages so that you can once again run the OEM O2 sensor?
You do not need to make any changes...just make sure you change your rom image to be in closed loop.
Jaker
Post by Jaker »
So to use the edited tables, and enable the WB voltages, is it absolutely necessary to set the O2 sensor to open loop?
lcopas
I have the same question ....
Post by lcopas »
bump ^
Do you run a PLX Devices Wide Band O2 setup in open or closed loop ?
turbosi92
Re: I have the same question ....
Post by turbosi92 »
lcopas wrote:bump ^
ALways tune with a wideband running in Open Loop
lcopas
Post by lcopas »
turbosi92 wrote:
lcopas wrote:bump ^
I know I'm gonna sound like a dummy ... mind you ... I'm trying to learn this on my own ... anyway ... I've been fighting my setup for the last couple of weeks ... could not figure out why I was not getting the result that I was expecting from my Hondata and wide band O2 setup.
Until I started tuning it it OPEN loop ... duuuuhhhh .... :shock:
Now after messing with it for just a few days ... I have almost got my low speed map tuned ... I have to do street tuning as there is no dyno in the town I live in ...
But I was having hell just getting the car to drive smoothly down the road, without hiccuping and misfiring, the drivability was SHOT ... I was really starting to get pissed off ...
Well ... now the car is running better and better everyday ... I only have an oppritunity to make a recording on the way to work and on the way home .. that's why it is taking me longer to get the map tuned ... I do a lot of trial and error.... but I'm getting there... a little at a time :)
