Injectors cut in and out.
EconoBox
Post by EconoBox »
Finally got my new H22a into my EG but now when I hold the throttle steady he injectors seem to cut out and the car bogs and the the duty cycle goes back up from zero and its fine fo a few more seconds. Please help ASAP I would like to get this car on the road.
Martian
Post by Martian »
post a datalog if you want the Hondata guys to chime in.
thank you, thank you, I'm here all week
EconoBox
Post by EconoBox »
I think my actual ECU needs repaired. :(
I popped in the stock p13 and the car runs great. A little rich but no problems yet.
EconoBox
Post by EconoBox »
I put my s300 into a virgin p28 and I am still not able to run the car with the s300. The car will start and run but if i give it throttle and hold it steady it will cut out and drop down to idle and then jump back up. The ECU blinks a red light when it is turned on and stays green the rest of the time. Any suggestions would be greatly appreciated. Again with a stock p13 in the car it runs fine. This is in an EG.
I will post my datalog tm night.
cardinal811
Post by cardinal811 »
I had this issue before going solid rear mount. The motor is rocking and smashing the TPS. Check to see if cracked or if it's not a rivit styled one check and see if the screws are loose. Whats happening is that you push the peddle and its clocking the tps it self advanced. Then when you hold it steady the spring return pressure on the TPS rocks back more than it should and you have -voltage and the Injectors cut out
imratedpg
Post by imratedpg »
EconoBox wrote:I put my s300 into a virgin p28 and I am still not able to run the car with the s300. The car will start and run but if i give it throttle and hold it steady it will cut out and drop down to idle and then jump back up. The ECU blinks a red light when it is turned on and stays green the rest of the time. Any suggestions would be greatly appreciated. Again with a stock p13 in the car it runs fine. This is in an EG.
i have this exact problem! i fixed it by calibrating the minimum and max readings of the TPS.
93 EG Hatchback GLi + 97 JDM H22a + OBD1A Hondata S300
imratedpg
Post by imratedpg »
...The ECU blinks a red light when it is turned on and stays green the rest of the time...
Can someone please tell me and the poster if this is normal for the s300 to do this?
Martian
Post by Martian »
no this isn't "normal". We need to see a datalog.
