97 Prelude h22a5 ecu tuning
Infiniteprelude
Post by Infiniteprelude »
Is there anything that will work for this engine? thanks
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
