K-Pro Dual and Kraftwerks Reflash
Elroy
Post by Elroy »
Since Kraftwerks uses Hondata to reflash the factory ecu; how will the kw reflash be affected by the new K-Pro Dual, if any?
J
Hondata1
Post by Hondata1 »
The Kraftwerks reflash is replaced with program that enables the ECU to be used in a Dual ECU configuration. The stock ECU is in effect dumbed down.
Elroy
Post by Elroy »
Hondata1:
Thanks for the FAST response!
Since we get a box of "dumber" back with more toys included, is there a KW.kal, KW image, or KW notes to smarten the "DUAL" back to the base KW settings?
Last dumb question! Again Thanks!!
J
Hondata1 wrote:The Kraftwerks reflash is replaced with program that enables the ECU to be used in a Dual ECU configuration. The stock ECU is in effect dumbed down.
Hondata1
Post by Hondata1 »
Not yet. We will co-ordinate with Kraftwerks to develop this base map.
Boofster
Post by Boofster »
I was waiting for this myself.
You can now reliably get the KW 'youtune' kit and set it up properly.
I am guessing an old reflash kit will work just fine as they just reflash your ecu again. You'll just need to go retune it yourself.
Waiting for basemap so my car doesn't blow up from my house to the dyno :)
Da Boost
Hondata1
Post by Hondata1 »
Basemap tuned yesterday and posted here:
http://www.hondata.com/forum/viewtopic.php?t=8857
The car made around 400 HP on Church's dyno with headers and stock cat. Injectors were at 100% though.
Elroy
Post by Elroy »
SAWEET!
I will be heading over to the shop Monday to make my order! What header and what cat/exhaust?
J
Hondata1 wrote:Basemap tuned yesterday and posted here:
The car made around 400 HP on Church's dyno with headers and highflow cat. Injectors were at 100% though.
Hondata1
Post by Hondata1 »
correction - stock cat
Boofster
Post by Boofster »
Question:
What is the "E20" wire sticking out of the harness for?
Da Boost
It is an output from the K-Pro you can use with nitrous/Aux controls.
