S300 problem
hp1
S300 problem
Post by hp1 »
I have a P06 w/ S300, I cannot get the ECU to throw a check light. I have unplugged random sensors to try and get a check light but no luck. Any ideas? car runs fine... thanks
you may have a burned out bulb.
hp1
Post by hp1 »
Light bulb is good, I see it coming on at start up. Have you ever heard of a problem like mine? tia
Do you get error codes when you datalog?
hp1
Post by hp1 »
Hey, I do not get error codes while in datalog. I now can get a couple sensor to throw a CEL but that's about it. help
does the mil light come on if you set the shift light to 2000 RPM and rev the car over 2000 RPM?
hp1
Post by hp1 »
Yes, CEL light comes on with shiftlight @ 2K.
Then it does not sound like there is a problem.
