Socketing issue with JDM ecu
OTT
Post by OTT »
Hi Ive socketed half a dozen JDM ECUs with no problem before but I have one no and a row of the six pins are not functioning.
as you look at the picture of a JDM ECU in your help-file for Smanager,
on the lower row of pins, the first two pins are fine, the next six are not illuminated, and the nex six are fine.
could this be relative to the latch-IC in IC4? ...since I desoldered the bad pins, cleaned the contacts, then re-soldered them and yet I still have the same issue. ?
Does it work correctly with the s300?
OTT
Post by OTT »
I have not tested it in a vehicle because of the 6x none-illuminated LEDs.
What do you suggest?
Try it with the s300 in a vehicle.
