Kswapped w/ Kpro & Wat/meth on Nitrous Controls
NtegraDryvr
Post by NtegraDryvr »
I enabled nitrous 1, I plugged into E29 for Arming input and E21 for Arming output and uploaded the changes to the ecu. Flipping the switch does not change anything that I can see and I am looking in the tables under N20 Arm and it stays at Off. I have tried inverting both and no change other than if I invert the arming input it switches from n20 arm off to n20 arm on and the switch has no effect.
So,
E29 = Switch
Switch = E29 / Ground
E21 = Relay
My switch does light up when on and turn off when flipped off. Kpro shows no change anywhere.
See http://www.hondata.com/forum/viewtopic.php?t=3629
Usually the conditions are incorrect.
