Smanager wont upload my calibrations to hondata s300
Colocho19
Post by Colocho19 »
Like the tittle said my smananger wont load my calibrations, its a brand new p06 converted to a p28 and with the s300, ive got all the software installed and the usb drives are working fine cause everytime I turn on the egnition key the software tells me thats "on line" but when I open the calibrations i want to upload from my computer to the s300 and i click on upload nothing happens and when i try to download the calibrations from the ecu nothing comes up either, could someone help me or tell me what im doing wrong please im new to hondata so please take it easy with me. thanx in advance.
i have a 92 hatchback with a h22a motor and the motor is no where near stock everything is aftermarket fully built ect.., u get the idea.
If you click on the information button, what shows up?
Who socketed your ecu and what is the s300 serial number? What is the version of software you are using from Help, About?
Colocho19
Post by Colocho19 »
First I turn on the egnition key then the manager state that's "online" then when I click on information I remenber that a pop up came up but with blank fields like there must be some info on those fields that are not coming up its like the manager is not reading the ecu.
I bought the ecu with the s300 already socketed into it and the guy that I bought it from said that it was done proffesionally, the serial number I could give it to you later on cause im at work and I have all of that at my house and the version im using is the latest smanager thats from the website.
The serial number is 6291
Please call us with everything in front of you in the car so we can troubleshoot. If we find there is a problem, we will instruct you further at that time.
Colocho19
Post by Colocho19 »
thats it? i was expecting a little more help.
Colocho19
Post by Colocho19 »
could someone please help me out with this problem! I dont know if theres something wrong with the ECU or is just me doing something wrong.
Martian
Post by Martian »
I advise you do as you were asked. Not everything can be fixed over the internet.
thank you, thank you, I'm here all week
Colocho19
Post by Colocho19 »
well thanx for tryna help me I fixed the problem already it was that ma friend took the chip out the my ecu to tested on his ecu cause his is not working and he thought that it was that he had a bad chip but still my chip did not work on his p28 so when he put it back in to my ecu he put it back wrong he missed like 3 pins off and i placed it back the correct way and now it works fine and i was able to upload the map into the ecu, thanx anyways.
