Cold start and idle issues on H22A
jdmrocket
Post by jdmrocket »
I have JDM P30 running H22A7 from Accord Type-R.
Just after start up RPM is significantly lower than specified in the calibration during warm-up for about a minute.
Another issue is with idle: I can't set idle RPM lower than 850. This must be a problem with ECU. Because if I plug EDM P30 ECU with the same calibration I can set any RPM. I've played with IACV duty cycle - did not help. If I unplug IACV plug the engine idles at 500-600 RPM.
Is your IACV 2 or 3 wire?
jdmrocket
Post by jdmrocket »
Spunkster wrote:Is your IACV 2 or 3 wire?
Originally it had 3-wire IACV but I put a 2-wire one.
If it is working correctly with your conversion and a different ecu with the s300, then you may have a damaged ecu.
jdmrocket
Post by jdmrocket »
Spunkster wrote:If it is working correctly with your conversion and a different ecu with the s300, then you may have a damaged ecu.
I doubt that. A friend of mine has the same problem (high idle) with JDM p30.
As for low RPM on warm-up - could absence of FITV be the cause? If yes why Hondata does not have an option to compensate?
