RSX with ITR cams and hondata #4......
LI RSX 02
Post by LI RSX 02 »
I currenty have hondata in my car with the lowered vtec point and raised rev limiter. I am really considering the itr cams and i wanted to know if i would run into any problems using the itr cams with the hondata #4 program? I will eventually upgrade to the itr flash when im able to take off of work for 3 days. I would appreciate some good feed-back.
R Cams & #4 flash
The Type R cams will make the engine run a little lean above 7000 rpm, but not dangerously so.
