Need a map for a built H22
h22luda720
Post by h22luda720 »
Btw, Hello hondata forums! :D
Heres the specs
H22a1
S300 With PWM boost support
GM 3 Bar map
Darton sleeves
Balance all rotating internals
Scat rods
Wiseco pistons 9.5:1
Stock head, Cams, IM & TB
Precision 880CC
Walbro 255lph
T3/To4e
Tial 38mm
RFL
thanks!!!
cardinal811
Post by cardinal811 »
Have you downloaded my map and just reduce the fuel maps a bit, works flawless for several users SEVERAL said thanks.
Probably pull some timing too maybe a degree or two across the board until you get it strapped on the dyno
h22luda720
The "DAVE FINAL MAP.Skl" ???
If so yea, havent got to try it yet though, thanks!
h22luda720
Tried it out
Cut back some timing for safety sake till dyno day, changed injector size, and had to cut back some fuel.
Worked Great! BEAutiful lambada overlay, ran great, idled better, plugs look nice and tan after a couple of parking lot passes.
I vote for a sticky tune
h22luda720 wrote:I vote for a sticky tune
Done.
cardinal811
