jrsc standard program will it fit?
SpoonPL
Post by SpoonPL »
Hello just recived my s300j. question my current setup is b16a on p30 small case - jrsc supercharger with rc 440 injectors and pulley from crv 4-2-1 header with out 2.5''. previously tuned by crome showed 0.7 bar maximum. can i input on my s300j b16a jrsc program without any problems or i had to tune anyway?
I'm sorry, but I don't understand the question.
SpoonPL
Post by SpoonPL »
with SManager you can download program for jrsc b16. with my setup which is highier may i input on my hondata this ready program / start engine and run without worries about any damages or i had to check it anyway (afr) or retune/make corrections? i hope it is clear now
You may have different fuel and also the intake and exhaust may make some difference. The calibrations built into the software will give you a good starting point, but you should always check your air fuel ratio and may also be able to get more power by fine tuning on the dyno.
