suggestion ?
FreshDA9
suggestion ?
Post by FreshDA9 »
i was looking threw Smanager and i was thinking it would be nice if you guys would fix the fuel and ignition tables in the nitrous controls. there is about 6inch's of empty space on the Parameters and if you look at the fuel or ignition you have to click down on the bar to make a change. Its not a big deal just figured you could extend them down some since there is alot of space. thank you.
Resize the parameters windows & make it wider.
FreshDA9
Post by FreshDA9 »
i can drag the box around wider or taller but still wont show the rpm and correction for both fuel and igniton in the Nitrous Aux controls. and the only thing you can change in settings is parameter table tracing.
i dont wont wider box i wont to see RPM and Fuel without clicking down or up arrow. same with RPM and ignition.
