Proper TPS Readings - Settings
Crxmanror
Post by Crxmanror »
I'm new to K-Pro and have a question related to the TPS readings im getting. According to K-Pro when the car is at idle it reads 0% which is correct. Now when you push the pedal to the floor it reads 102%. Is this correct? Is there any changes in the software that I may need to change?The TPS has never been messed with that I know of so I assume this is how it came from the factory.
A reading of 102 at WOT is fine and will not cause any problems.
Crxmanror
Post by Crxmanror »
thanks for the info...
fonz600
Post by fonz600 »
If you have acopy off your map you could make sure the Scale TPS readings are correct as they sit at 0 and 100 normally on the base maps.
It's under Parameters, Knock/TPS then just hit read on each off the throttle settings to set it to your car and then save it and re upload.
