TPS setting not match datalog
dcloo
Post by dcloo »
hondata,
i have been calibrate my tps setting under Parameter/TPS the reading was 0
when on datalog the TPS was start reading 1% when the motor was around 2300-2500 rpm
i have replace few unit TPS sensor but its still having same problem
and here was my datalog
The uncorrected TPS is slowly changing from -1.7% to 1.3% during the datalog.
How do you get 2300 rpm with no throttle?
it looks like a vacuum leak or somethign is making your throttle body open. CHeck teh tension of the cable to make sure that it is not too tight.
dcloo
Post by dcloo »
the problem was there the car was at idle and i press the pedal up to 2300-2500 rpm and only the TPS start reading
i have check every things like the cable/cable bracket at throttle body, BDL 70MM throttle and its confirm no leaking around RBC intake and the BDL cause its was idle constant at 1000 rpm
and now i was found another things when WOT the TPS was reading max 94-96% and i check it again its was fully open nothing wrong with the cable and the pedal and also the bracket
could this was ECU faulty?
that's was lots of knock count but the motor was still on tuning and found this problem
This is not an ECU problem. It is either a problem wih the TPS sensor or more than likely a problem with the throttle body
