lsvtecem1
Post by lsvtecem1 »
I have a question. How do can I convert a .bin file to .skl? I have an Ls/Vtec .bin map but need it to be .skl for Smanager. Thanks in advance.
In Smanager, go to File, open, make sure you have the file type set to all and open the bin you want to use.
lsvtecem1
Post by lsvtecem1 »
I have tried that but when it opens the .bin file and I go to the Tables tab, the graph is all screwed up and all the numbers are too, even the rev limiter fuel compen. and so on. :cry:
Check the size of the bin file - if it is not 32768 bytes, then it is another file format renamed to .bin.
lsvtecem1
Post by lsvtecem1 »
Oh okay, its 48000 bytes. well I have another question. How do I go from 1.6 to 1.8 liter when using a P30 Basemap?
Under Parameters in the Fuel Trim tab, click on Calc.
lsvtecem1
Post by lsvtecem1 »
Will try it out when i get a chance, but thank you for helping me. :D
