HELP PLX INSTALLATION S300
celicagt4
Post by celicagt4 »
THERE IS ANY WAY TO CALIBRATE THE M300 PLX WIDEBAND OR IS JUST INSTALL THE WIDEBAND AND I DON'T HAVE TO DO ANITHING IS GOING TO BE COMPLETED AFTER INSTALLATION? PLEASE ANY ADVISE :(
hiperformance
Post by hiperformance »
I would search the help files or this forum for more in depth information. but....
Go to: parameters, Closed Loop. the wideband lambda table is at the bottom of that page. I believe the voltage/ conversion table is already preset for the PLX. 0v=10 and 5v=20. from there you choose which input source you are using and change the offset voltage +/- (start small) like 0.1 or -0.1 until the display on your laptop matches the display on the PLX. at least thats how i did it. if thats not right, someone else can chime in.
