h22 turbo - Car won't start
ripsta
Post by ripsta »
I’ve got my turbo Accord finished but have a possible wiring problem I could use the forums input to help address. It is a prelude motor with prelude wire motor harness plugged into Accord sub harness going to the ECU. I’m using S300 Hondata ECU for Reference. I’m attached a spreadsheet for the PIN outs to the ECU for the 3 cars to see what is different and needs to be changed…
We first installed the Accord ECU into the car and we had spark and fuel pressure but of course it wouldn’t fire the motor being that I have over double the injector size and we tried to lower fuel pressure also just to see if it would start but no go…. The S300 wouldn’t give the car fuel pressure when plugged in and a custom map for the motor loaded… We tried about 6 different maps to see if that was the issue and it wasn’t; then we thought it was the ECU so we tried it in my Del Sol and another 92 accord with H22 motor and it ran both with no problems….so we think it is a wiring issue…. Take a look at the spread sheet and see if you see something that might be causing this?
The excel file not allowed so tired to paste it below!!!
The only things I saw different were the Map sensor pin location that might throw the custom ECU off….
PIN 93 Civic 1.6 P28 94 Prelude P13 95 Accord EX 2.
a1 inj1 inj1 inj1
a2 inj4 inj4 inj4
a3 inj2 inj2 inj2
a4 VT sol VT sol vtec spool valve
a5 inj3 inj3 inj3
a6 htcntl O2 HTC O2 HTC
a7 flr1 flr1 flr1
a8 flr2 flr2 flr2
a9 eacv IACV IACV
a10
a11 E sol E sol
a12 fanc fanh fanh
a13 warn mil mil
a14
a15 acc acc acc
a16 acgc altc altc
a17 atlsb sv sol blank
a18 fas fas
a19 atlsa res sol IAR sol
a20 pgs pcs pcs
a21 igp1 icm1 icm1
a22 igp2 icm2 icm2
a23 pg1 pg1 pg1
a24 pg2 pg2 pg2
a25 igp1 igp1 igp1
a26 lg1 lg1 lg1
b1 igp2 igp2 igp2
b2 lg2 lg2 lg2
b3 atd3 afsa afsa
b4 atd4 afsb afsb
b5 acs acs acs
b6
b7 cl/npsw atp pn atp pn
b8 psw psp sw psp sw same
b9 sts sts sts
b10 vsp vss vss
b11 cylp cyp p cyp p
b12 cylm cyp m cyp m
b13 tdcp tdcp tdcp
b14 tdcm tdcm tdcm
b15 crnkp ckpp ckpp
b16 crnkm ckpm ckpm
d1 vbu vbu vbu
d2 bksw bksw bksw
d3 ks blank knock sensor
d4 scs scs scs
d5 Baro out(auto trans)
d6 vtpsw vtpsw Vtec oil pressure switch
d7 txd/rxd txd/rxd txd/rxd
d8
d9 acgf altf altf same
d10 el el el
d11 th tps tps
d12 egrl egrl
d13 tw ect ect same
d14 o2 o2 o2
d15 ta iat iat
d16
d17 sg1 map(pb) map(pb)
d18 sil/slu vref vref
d19 vcc1 vcc1 vcc1
d20 vcc2 vcc2 vcc2
d21 pb sg1 sg1
d22 sg2 sg2 sg2
95 Accord EX; JDM - H22: ARP head studs Cometic gasket; compression dropped; Moroso Oil pan; AEM fuel rail, 680cc injctrs & pressure regulator; 255 pump; T3/T4 turbonetics kit. 5spd stage3 clutch, light flywheel. Hondata S300
You have already determined it is a wiring problem, so now you need to track that down and correct it.
ripsta
Post by ripsta »
Why would I not have fuel pressure by just switching the ECUs? Looking at the Accord vs Civic(P28) cars ECU pin outs they are 98% the same especially the PINS that would activate the fuel pump and everything that is important to run the car.... I'm not seeing what the possible wiring issue is...
I was able to convert the Excel file to a gif image file...it is attached.
